SEEKING HELP: vtec wiring into the crix
according to hasport.com, i only have to wire up 4 additional wires(i have an 88 si) to the ecu from the b16. i think they were vtec pressure, knock sensor, and two others. i know the ecu location for each wire but the main problem is i don't know what each wire looks like. can someone please post pics of wires/sensors and label each one. i really appreciate everything. thanks.
Re: SEEKING HELP: vtec wiring into the crix (88'CRIX)
hybrid page might help..? http://hybrid.honda-perf.org/tech/4gtech.html
Re: SEEKING HELP: vtec wiring into the crix (milo)
The wiring on the left is for the JDM B16a, the right is the 88-91 Si... You can reuse your Si engine harness.
[Modified by Trey, 10:15 AM 12/26/2001]
Re: SEEKING HELP: vtec wiring into the crix (Trey)
even easier a8 turn into vtec selonoid
c8 secondary o2 sensor
b5 vtec oil press and ground
b19 knock sensor
tehere you go.
b19 knock sensor
tehere you go.
Cynical 1
09-23-2002 04:41 PM
HybridRexy
05-05-2002 08:19 PM
