Anyone ever had a problem with enlarging the dowels to 9/16" instead of 14mm?
I had the dowels on my B16 head moved to use on my CRV block, but the shop (or any shop I called) did not have a 14mm mill drill bit, the closest they have is 9/16" which is 14.2875mm.
I just picked the head up from the shop and the dowels move around a bit in the holes, but not really too bad.
Alot of local people who have done this said they havnt had any problems.
Similar experiances on here?
Re: Anyone ever had a problem with enlarging the dowels to 9/16" instead of 14mm? (HX_Guy)
its fine.. just maek sure you line up the head as best you can with the block.
G3-TEG: What did you guys utilize for a PCV system on the B20VTEC on your site?
isotopesope
02-28-2002 04:52 PM
HX_Guy
01-04-2002 05:41 AM
