Help installing B18C, into Civic VX
I'm helping my friend install a B18C in a 95 Civic VX HB we were doing good until we got to the engine mounts. Now someone told us that we had to use the engine mounts from the civic engine onto the B18 but when we took the mounts off the civic motor the driver side top was held on by one bolt. On the B18 it was held on by 3. I need to know if this is right cause it feels weird holding on to one bolt. Does anyone know what I'm talking about?? and can help?
Re: Help installing B18C, into Civic VX (RuskeR)
If you're installing a B18C motor then you dont need to use the civic motor mounts you use the stock motor mounts that came with the B18C. The motor should be a darect fit.
all you need is the rear mount/bracket from the integra. all the other stock civic ones will work.
btw, who are you guys? i'm in olympia here (during break at least)
I have that same swap in my 92 VX. I used all 3 factory B18C mounts that came with the motor - driver side, tranny, and rear. If you need any help with wiring or anything else let me know.
[Modified by VTECVillain, 8:37 PM 1/3/2002]
eg6hatch
07-08-2003 12:39 PM
