B18C1 swap question....
Re: B18C1 swap question.... (Type R106)
i think someone here needs to make a frequently asked question forum or link. everyday someone askes this same question, and everyday, Trey will come along and give this link http://hybrid.honda-perf.org/tech/6gtech.html . or, some of these guys need to learn how to use the search button and some common sense.
you need the rear mount and tranny mount from a 99-00 si, you can add the extra wires for the knock sensor and secondary butterfly to your harness. You'll need the radiator hoses from a gsr and all the other normal stuff like engine, tranny, ecu, axles, and shift linkage from the integra. Also, if you can get the cat. converter, your exhaust should line up then. I think that's it but check hybrid-honda and look at the wiring. Their pretty good about showing what to do. You also might want to pick up a helms manual for both car it help with the wiring as well.
good luck!
good luck!
Banned
Re: B18C1 swap question.... (civic97dx)
keep ur old motor....ur gonna need some mounts off of it.....I just put a ls motor in my ek...I created a thread a while back about how to wire it up....do a searcha nd look for topics that I created
good luck!
good luck!
92-LS-Civic
11-07-2004 05:44 PM
Nikos
08-26-2002 12:27 PM
