cant get it to turn over
Old Apr 15, 2003 | 04:34 PM
Fokis05's Avatar
Default cant get it to turn over
just put my b18c1 back in and it wont even try to turn over all that happens is my fan comes on when i go to turn it over.
another thing where do the ground wires go? i grounded the one off the valve cover but what about the other? and could this be why it wont start?
thanx for any help
Old Apr 15, 2003 | 05:49 PM
VTEC-DA's Avatar
Default Re: cant get it to turn over (Fokis05)
Are you getting spark and fuel?
Old Apr 15, 2003 | 05:59 PM
Fokis05's Avatar
Default Re: cant get it to turn over (VTEC-DA)
its like im getting no power to the starter but i tested it and it is getting power
Old Apr 15, 2003 | 06:20 PM
b20ek's Avatar
Check and make sure all of your ground wires are connected. Make sure that you have the ground wires to the throttle housing connected. Also is your car a standard conversion? I was putting an engine in for a guy and the engine didn't turn right away because you have to engage it in park.
Old Apr 15, 2003 | 06:45 PM
Kamin's Avatar
the transmission ground? its more important, very thick black wire on top of the tranny, near where the slave cylinder lines mount to the frame
Old Apr 15, 2003 | 08:02 PM
Fokis05's Avatar
Default Re: cant get it to turn over (Kamin)
it runs!! i guess the ground on the tranny wasnt good so i moved it and it fired right up. thanx for the help
Old Apr 15, 2003 | 09:04 PM
Dmotor2nr's Avatar
If you dont hook up the grounds properly, it will not run or start at all!
92eg6_pino
Oct 9, 2010 04:56 PM
Fuzion
Sep 3, 2004 12:08 PM
SpoolinEK
10
Oct 27, 2003 04:27 AM
hybrider
Mar 24, 2002 10:32 PM
ZColeon
10
Oct 24, 2001 09:07 AM
