swap still wont start???
Iam not getting any spark, the fuel pump is kicking on but Im not sure if the injectors are pulsing, I think they are.
I have checked every ground and all of my wireing and everything seems to be good
the car turns over, but it just wont start.
when I pull the plugs they are not wet, but I can smell some fuel.
I am positive Iam not getting spark, I am getting power to the (+) side of the coil
I have a crx si with an OBD2 b18C
I am useing a stock OBD1 p28 ecu with a blown hatch convertion harness
i am useing my stock crx injectors with the resistor box.
can anyone tell me if I did something wrong or if you have any ideas on what I should try.
I did rtry another coil and igniter and that didnt help.
thanks
thanks
Re: swap still wont start??? (DOHCarp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCarp »</TD></TR><TR><TD CLASS="quote">Iam not getting any spark, the fuel pump is kicking on but Im not sure if the injectors are pulsing, I think they are.
thanks
I think you cannot use OBD0 injectors on a OBD1 system.
thanks
