H22 swap to EK...gas line hose?
got a couple more ?'s
-gas line hose is approx 6 inch short?....but has *banjo* type ends on it, does this have to be custom made?
-will 94 Del Sol Lower rad....cool the car well for normal driving?
-any other rec's lemme kno
Re: H22 swap to EK...gas line hose? (Ddogz15)
Use the prelude fuel hose, it should be long enough or you can get a aftermarket fuel rail, where the fuel will enter on the left side instead of the right.
You'll need to extend the hose. One of the ends needs to be the civic end (on the fuel filter) and the other side needs to be the prelude end.
You can either make your own with an extended fuel line you can purchase, with hose connectors and hose clamps, or you can have one custom made from a local hose store in your area.
I would recommend getting a custom hose made from the local Hose place (this is waht I have) and works wonders.
As for the radiator, any dual core radiator will work. HTH.
Re: H22 swap to EK...gas line hose? (poison)
Well, I just cut my stock fuel line and got some fuel line specific barb thingies and got a piece of fuel injection hose to extend. I jsut used 2 hose clamps on each side of the fitting. So, basically, I got a length of hose, 2 barb fitting thingies (talk to the AutoZone guys, it's on the shelf someplace) and 8 hose clamps. Mine has yet to leak.
Re: H22 swap to EK...gas line hose? (EK22Tim)
Hey Tim, when I had that I had kinda of a small hose connector, and my engine was leaning out BIG TIME, you have that prob at all? That's why I got 1 custom hose to it's a constant smooth flow.
Heres a pic of where my fuel line connects to the filter, you can basically see what I did, pictures says thousand words. I cant seem to get a good pic of where it hooks up to the motor right now, I get to much glare, so maybe later Ill get a better one.
Modified by junglerunna02 at 5:33 PM 4/28/2003
Re: H22 swap to EK...gas line hose? (junglerunna02)
Wow, really? That would suck if I'm running lean. My A/F ratio blinky disco light doesn't tell me that I'm running too lean. Come to think of it, it is kinda small. Crap. Where did you get your fuel line? I may want to redo mine for safety's sake. hmmm.. *scratches chin*
Junglerunna nice routing job. I like the factory bracket too. Mine runs under the intake manny with some zipties keeping her safe. hey, can't see it so no harm done.
D16SohcVtec
06-27-2008 07:01 AM
Seedc2
07-11-2005 12:27 PM
