How do you change an auto P30 ecu to a manual?
How do you change an auto OBD2 P75 ecu to a manual?
I've heard that you can change the resistor # RP18 from 2.4kohm to 1.4kohm but I'm not sure. Can someone confirm if this is true or not?
The reason I ask is because I keep throwing code 70, which is the auto problem code.
<I tried to search, but the damn search function wouldn't check for ecu, ls, or P75 )
Modified by hypa at 11:17 PM 4/17/2003
r2d97
03-05-2006 05:34 PM
your username here
11-29-2003 04:58 PM
