axles
Old Apr 16, 2003 | 07:36 PM
bOOsTiNSoHcVtEc's Avatar
Default axles
Bought 94 and up integra axles and they didnt fit...what axles do i need wen dropping a b18b into a 95 civic ex
Old Apr 16, 2003 | 07:49 PM
poison's Avatar
Default Re: axles (bOOsTiNSoHcVtEc)
Those should fit. Where are they not fitting?
Old Apr 16, 2003 | 07:54 PM
Default Re: axles (poison)
like you kno...one side has that groove fitting?? well the other side doesnt so i cant put it into the brakes. Will ex axle work??
Old Apr 17, 2003 | 08:26 AM
1bad-eg's Avatar
Are you sure you have the right axles?
Old Apr 17, 2003 | 09:26 AM
IS3Fifty's Avatar
Default Re: axles (1bad-eg)
ok so you have 94 motor with 94-95 axels, thats what we will say. They go in. Do you know there is a clip in the tranny?? you have to get the axels to clip into those... **** i forget what they are called... starts with an "s". anyways, you need to push and twist. Once you hear a little click sound you know you have them clipped in.
Old Apr 17, 2003 | 09:50 AM
Big Teggie's Avatar
They should work. Maybee you got the wrong axles.
Old Apr 17, 2003 | 11:01 AM
Newman's Avatar
New User
Default Re: axles (Big Teggie)
Before everyone tells him he's got the wrong axles, check your intermediate shaft first. If you have 94+ Integra axles, then you'll need the 94+ Integra intermediate shaft. If your motor came with an auto intermediate shaft, then you need to swap it out for a 5-spd (they are different... we have both here at the shop).
FYI, on your swap, you can use 94+ Integra axles w/mid shaft, 90-93 Intgra axles with 90-93 mid shaft, or 92+ B16 axles (similar to GSR axles) along with SiR2 mid shaft.
Old Apr 17, 2003 | 11:49 AM
SilverJdmhatch's Avatar
Default Re: axles (Newman)
Do you have to swap out your axles when putting a B18b in a 92 hatch???sorry for whorin the thread
Old Apr 17, 2003 | 05:21 PM
Default Re: axles (SilverJdmhatch)
I found out what the problem was guys...the guys i bought the motor from put a A1 cable tranny on it so my intermediate shaft was from a 90-93 integra so i need 90-93 integra axles. But im not going to do that...im jus gonna sell my tranny and buy my friends hydro gsr tranny. Anyone wanna buy da tranny jus contact me...thanks fer all ure help guys!
HondaCRZY
Feb 21, 2015 05:43 AM
turbotegy10
May 20, 2010 05:55 PM
lilpastrana
Sep 6, 2007 07:30 AM
HamiltonRex
Feb 22, 2006 03:58 AM
