need some help here??swap wont start??
well we just put in a 2000 B18b into a 95 civic coupe..and it wont start...were using a 94 ls distributor,97 ls ecu, with dx injectors,and an auto obd1 harness..its gettin fuel and spark..but wont start..any opinions????
Re: need some help here??swap wont start?? (k12ayz1e)
How do you know its getting spark. If its getting fuel and spark then it should start. Did you do an auto to standard conversion?
Re: need some help here??swap wont start?? (b20ek)
because we pulled out tha plug with tha wire on it still an started tha car and it sparked..its a standard..
Check all the grounds. I just did a 1998 b18b swap in my 1992 civic and I had the same problem. I looked on the back side of the motor around where the starter is and I had a ground wire hangin that wasnt hooked up. I hooked it up then it started right up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k12ayz1e »</TD></TR><TR><TD CLASS="quote">so 97hb use a obd2 ecu???</TD></TR></TABLE>
I would use a obd1 ecu if possible. OBD2=emmision hassles.
DeviousCTR
14
05-04-2006 03:28 AM
integra-modder
03-22-2004 06:22 PM
