ok, here is my frustrating fuel problem.
well I got my swap in, drove it around the neighborhood (wasn't legal yet!) was happy with it, put the rear interior in, hasn't run more than twice sense. I would get in, wouldn't here the pump prime up. I figured relay, used a friends relay, nothing. I swapped pumps out, nothing. I can run a straight wire to the pump and it cuts on and starts pumping. I can't get it to switch on and prime with the key though, only way I can get power to the pump is by either straight wire from battery or through a switched power. Would the car crank up and run and no problems occur if the pump was wired to a power source instead of through the ecu and relay per say? I am highly frustrated, had to put the tools down and walk away from it last night (that bad, sure you guys know all about that!)anybody ever had a similiar problem, experience, advice, support........something! Help a H-Ter out!
Re: ok, here is my frustrating fuel problem. (ImprtTuner88)
did you check fuses??? probably a stupid question but we have all overlooked them at least once or twice in our lives, only to find out it was something that simple.
Re: ok, here is my frustrating fuel problem. (BurntRice009)
yeah, should have put that in here (can you tell I am frustrated!) no fuses are fine. I don't get power back through that wire that plugs into the pump. I tested it using the method of putting the probe into the yellow wire plug and grounding it, and I tested it using the method of putting the ground in the ground prong and the probe in the yellow one. I would love to just rerun those wires if I knew it was just the wires that were bad.........like knicked or something, I just don't know.........
boosteddohczc
10
06-11-2009 09:57 PM
