00 b16a2 into 98 civic dx swap problems
i swap the engine in it fit fine,at first the engine would crank but would not start,then it started but idles really bad,i check everything,the spark plug wires dont have spark,but it still turns on.can somebody help!!!!!!!! i rewire a 98 ex harness to fit the si ecu.
Re: 00 b16a2 into 98 civic dx swap problems (jcivic)
Wires don't have spark, or the spark plugs themselves don't spark? Did you ground whatever you used to test the spark?
If it is the plugs try replacing them. Elaborate in english for more precise answers.
Re: 00 b16a2 into 98 civic dx swap problems (lazy bum shaughn)
i know but i bought the plugs that go into the ecu and rewire the harness to fit.another thing does anybody know what to do with the 2 o2 sensor,where do i put it ,and plug it up?
