Which distributor does the 1st gen b-16a use???????
I've got a 4th gen. hatch with a 1st gen b-16a in it. I'm thinking it's time for a new distributor but I don't know which distributor to use. I know I can use the cap and rotor off of a 90' teg. they are exactly the same, but I've heard that I need a v-tec distributor and a 93' gs-r won't fit the bolt pattern, or so I'm told. Any information on this particular problem will help out alot.
Re: Which distributor does the 1st gen b-16a use??????? (fast-hatch82)
There is no direct fit US counterpart for the OBD0 B16A distributor. You'll either need to get another one, have your's rebuilt or use a 90-91 Integra LS and modify it to fit which some people do.
Re: Which distributor does the 1st gen b-16a use??????? (VTECVillain)
what he said.
but you can buy this one here it will be a perfect fit!!!!
check out ebay b16a Distributor!!!
that guy has what you need!!!!
don't forget to read the number of the Distributor Housing!!!
and compare to his auction!!!
aim address: xbossman032x
if you need any help!!!
