H22a Setup- Tranny, axles, etc...
I am doing an H22a in an EG. I plan to use an 94' accord tranny. I already have HCP mounts and I plan to use the teg axles & accord midshaft set up. My biggest concern is, Will the HCP's(transmission bracket) work fine on the accord tranny?
Will the Teg axle and Accord Midshaft setup work fine as well?
Thanks in advance
Thanks in advance
Re: (redlineh22a)
90-93 Accord tranny will not bolt up to a H22. Only the 94+ Accord tranny will. Regardless of what transmission you use, you need to use the 92-96 Prelude rear tranny bracket from a H22 or H23 Prelude motor (not Accord).
Re: (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">90-93 Accord tranny will not bolt up to a H22. Only the 94+ Accord tranny will.</TD></TR></TABLE>
Wierd, aren't they the same motor anyways? *The Accords I mean...*
Re: (98CTRCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe »</TD></TR><TR><TD CLASS="quote">
Wierd, aren't they the same motor anyways? *The Accords I mean...*</TD></TR></TABLE>
hummm. whats different about them?? that [I]is [I] wierd.
Re: (hondaeg5)
My buddy knows someone who swapped an H22a in his 92 accord, So we'll ask him if you used the same tranny. Its not likely though.
It would be nice to save some $$$ on a little older tranny rather than a newer one.
Re: (redlineh22a)
they will bolt up just fine, all f/h series transmissions are interchangeable.. the casing is the same, i just swapped an h22 transmission to an fseries block.. clutches are also interchangeable across the board as well, only differences in 90-93 accord to newer accords is the model of the motor F22A1.. A2 and what not, transmission housing should remain the same...
Accord SiR-Turbo
03-23-2004 09:49 AM
H22ACiViC
02-17-2002 06:28 PM
d16y8
12-03-2001 08:26 PM
