need help w/ idle
Old Apr 16, 2003 | 08:09 PM
mistake_2's Avatar
Default need help w/ idle
running b16a1 w/ chipped p28 in eg. has b16a2 intake manifold w/ h22a tb. car idle bounces from 1000-2500 rpm. thought it was tps, and changed that. car now idles consistantly at 2500 rpm. what's wrong?
Modified by mistake_2 at 5:22 AM 4/17/2003
Old Apr 16, 2003 | 10:44 PM
RangerDan's Avatar
Default Re: need help w/ idle (mistake_2)
The idle sensor? Its the little black cylinder thing right behind the valve cover. Clean it out with carb cleaner.
Possibly the o2 sensor. I know theres something else to check but its slipping my mind sorry.
Vacuum leaks?
Old Apr 17, 2003 | 07:46 AM
pills_PMD's Avatar
Default Re: need help w/ idle (RangerDan)
what is the voltage on the tps?? .5 volts closed 4.5 v WOT
Old Apr 22, 2003 | 08:08 AM
mistake_2's Avatar
Default Re: need help w/ idle (pills_PMD)
still doing same thing. cleaned out idle sensor.... couldn't be o2 'cause when running chipped p28 can bypass o2. you'll get cel but runs fine. seen it before, just don't get emissions tested. replacing w/ diff tb w/ new map and tps. we'll see what happens
scooter2525
13
Dec 30, 2013 05:23 AM
kpop
Feb 18, 2008 04:40 PM
See Are X
Sep 22, 2003 05:16 PM
MeccaMan
Jan 28, 2002 05:33 PM
