best way to connect wires to ecu harness?
I ran wires for a gsr swap I'm doing to the ecu, but I dont have the proper connectors for them to go into the harness. Is this ok, or should I try to find the connectors. Would acura have them? Right now the ends are just pushed in so they make contact with the ecu pins.
Re: best way to connect wires to ecu harness? (743)
Unforunately, they do not have pin-outs. You'll need to get pins from another car (junk yard) and get them out then. That would be the best route and proper way.
However, if this doesn't apply, if you just want it to, you can just wrap up the wire and stock the wire inside the proper pin-out.
HTH.
HTH.
Re: best way to connect wires to ecu harness? (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">Unforunately, they do not have pin-outs. You'll need to get pins from another car (junk yard) and get them out then. That would be the best route and proper way.
HTH. </TD></TR></TABLE>
I took the pins from another car, but I couldnt uncrimp them, because the were too small. What gauge is the ecu wire anyway? 18? I'm using 16 and its a little big.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743 »</TD></TR><TR><TD CLASS="quote">
I took the pins from another car, but I couldnt uncrimp them, because the were too small. What gauge is the ecu wire anyway? 18? I'm using 16 and its a little big.</TD></TR></TABLE>
Just cut the wire a few inches back and splice the vtec wires in. PLug the pins into the ECU and you're good to go. What I did
hawj_boi_1
05-30-2006 05:54 PM
1 Cam Wonder
19
10-10-2004 08:49 AM
