95' b18b into 93' sol si (could use a litlle advice)
alright, im getting ready to buy a 95' b18b longblock and i just need a list of parts ill definatley need from people who have done this swap before, these are the things i know ill need if there is anything else please let me know...
engine/tranny/wire harness
axles(94+?)
ls ecu (what year should i get, since my harness is vtec do i have to change anything)
ls starter(any yr?)
ls shift linkage(94+?will it fit in a sol?)
all ls mounts besides rear tranny mount?
will i have to modify exhaust at all?
please if you can help me out, id appreciate it......thanks alot
axles(94+?)
ls starter(any yr?)
Re: 95' b18b into 93' sol si (sykotik sol)
your sol is obd1..so get an obd1 ls ecu. u shouldnt even need the ls engine harness. just use your sol's harness.
use 94+ ls axles and intermediate shaft.
get a 94+ ls starter.
you NEED the del sol dohc vtec (b16a) shift linkage. you can order this linkage from honda. no other linkage will work.
for mounts you need:
94+ ls driv side mount and driv side mount bracket (bracket that bolts to engine) .
94+ ls rear tranny bracket..you can use the rear del sol mount..but u need the ls bracket that bolts to the ls tranny.
i think the stock del sol top tranny mount will match to the ls tranny - not sure tho.
exhaust should match up.
cody_sandlin
08-09-2013 05:19 AM
