i have a problem...help!
i just recently bought a 97` coupe which had a h22 motor swap in it....and i am trying to go back to b-series into it...but i am having a hard time with the driverside motor mount...if u can help or have had this problem....please help...
i would post pics up, but i dont know how.... thanks,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkiii Eg »</TD></TR><TR><TD CLASS="quote">i am trying to go back to b-series into it...but i am having a hard time with the driverside motor mount...</TD></TR></TABLE>
I'm not sure which motor you are installing but unless it's a B16A2 from a 99-00 Si or directly from an EK, you need to change the driver's side mount bracket to the 99-00 Si and use any EK rubber mount.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
I'm not sure which motor you are installing but unless it's a B16A2 from a 99-00 Si or directly from an EK, you need to change the driver's side mount bracket to the 99-00 Si and use any EK rubber mount. </TD></TR></TABLE>
i figured out the problem...it was the body man who fucked up....he welded the mount on wrong...its was like 1/2 inch off....that blind ******// but thanks...i got it fixed today.....
UNKNOWN_MEMBER
Mar 20, 2007 03:43 PM
cates_07
Dec 25, 2006 04:45 AM
joedubovik
Nov 3, 2005 07:30 PM
