just finished b20vtec 12.5.1 compression into crx. got a couple ?
will post the setup and pics later on tomorrow.
well i just finished it up, but i have a few ?'s for the guru's. on the stock crx factory wiring harness. tere is a plug with a rubber boot around it and it has two pins in it. looks to me like it's the coolant temp fan switch connector for the radiator fan right? i am going to need to wire that up to the new b20vtec coolant sensor next to the thermostat housing right? also i also need to wire up the knock sensor, vtec oil pressure, and the vtec solenoid. where can i get this info.
deftones0817
10-17-2004 06:53 PM
tvrsir
06-28-2004 10:51 PM
paybac4223
03-15-2004 05:35 AM
