distributor and ECU HELP OBD0 TO OBD 2
I HAVE A 1990 HONDA CRX HF WITH THE 4- INJECTOR SET UP, I JUST DUMPED A D16Z6 SOHC BLOCK WITH A 1996 V-TEC HEAD. CAR WILL NOT RUN. IS THE OBD2 DISTRIUTOR THE SAME AS OBD0- AND IF NOT HOW CAN I MODIFY IT. ANYONE HAVE THE COLOR CODES THAT NEED TO GO TOGETHER
THANKS FOR ANY HELP,ALSO WHAT ECU CAN I USE THAT WILL GO RITE IN.
Re: distributor and ECU HELP OBD0 TO OBD 2 (crxjay)
if you are using a OBD0 ecu then just use the OBD0 SI dist as that bolts onto the Y8 head and that will plug into the stock SI harness. then for the ecu go zdyne one wire. the OBD1-2 dist timing is different than the OBD0 one.
777DYNASTY
03-21-2010 08:28 PM
89hatcher
06-05-2006 02:01 AM
4door93civic
07-21-2004 12:16 AM
civc 91
03-24-2004 09:29 PM
