Wiring help b16 (obd1) > b18 (obd1)
can you guys help me find the wiring for this? the b16 harness is the one from japan, the right hand drive vehicle and the b18 is from a left hand drive.
- i want to find out the wiring for the resistor box from the b16 to b18
and map sensor wiring
-basically I need to know the color matchups.
If there's info on a full b16 to b18 wiring conversion it'd be great..
thanks
thanks
Re: Wiring help b16 (93H22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22A »</TD></TR><TR><TD CLASS="quote">can you guys help me find the wiring for this? the b16 harness is the one from japan, the right hand drive vehicle and the b18 is from a left hand drive.</TD></TR></TABLE>
I hope you aren't trying to adapt the JDM harness into the US chassis. If so, good luck. I would definitely use a USDM harness and mod/add the necessary plugs and wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">- i want to find out the wiring for the resistor box from the b16 to b18
and map sensor wiring</TD></TR></TABLE>
If it's OBD1 then there's no resistor box for the injectors. The OBD0 motors and H22A's use a resistor box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">If there's info on a full b16 to b18 wiring conversion it'd be great.
The wiring for all OBD1 motors are pretty much the same. Certain models and ECU's have a few extra sensors, but for the most part all pinouts are the same.
Re: Wiring help b16 (VTECVillain)
thanks for the info,
i think he's trying to add a resistor box due to the different type injectors and i guess his map sensor wiring is off.
What's the difference(s) between the JDM and the USDM harness?
Xathine
05-05-2013 08:51 PM
jbell
06-19-2004 12:44 PM
