Will a gsr clutch fit a ls tranny?
I'm pretty sure that the only problem that you might run into is if it will line up to the Flywheel.
I have a B16 clutch going on a Ls But I have the B16 flywheel too. But I havn't put it on yet, I'll let you know in a month.
Re: Will a gsr clutch fit a ls tranny? (93si-hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93si-hybrid »</TD></TR><TR><TD CLASS="quote">I have a new gsr clutch but only a ls hydro tranny. Thanks</TD></TR></TABLE>
Yes it will work. All hydro B series clutches and flywheels are interchangeable.
Re: (UDubEric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UDubEric »</TD></TR><TR><TD CLASS="quote">are all b series cable clutches/flywheels also interchangeable as well then?</TD></TR></TABLE>
No, the 90-91 Integra's have a smaller input shaft so it uses a different clutch. You can interchange 92-01 B series clutches/flywheels. I know the 92-93 LS/GSR are cable, but they use the same clutch/flywheel combos as the 94+ hydro's. The JDM cable tranny's I can't identify by code as to which is like the 90-91 and which are like the 92+, just never had clear concise info on that.
Re: (Paulnsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paulnsx »</TD></TR><TR><TD CLASS="quote">arnt ls trannys cable and gsr's hydro (atleast 94+)?</TD></TR></TABLE>
ALL models of the 94-01 DC Integra manual tranny's are hydro.
ALL models of the 90-93 DA Integra manual tranny's are cable.
GSRontheBottle
02-19-2004 06:46 PM
