engine change
Old Jul 8, 2004 | 07:31 AM
paulieg's Avatar
Default engine change
here the question i have an 87 civic si 1.5L and i was wondering if i could swap the engine and trann with tha of a 97' 1.6L long block and still use the mounts that are in there now.
Old Jul 8, 2004 | 08:36 AM
VTECVillain's Avatar
Default Re: engine change (paulieg)
The 84-87 Civic mounts are very different from the 88-00 D series. The only way to swap a newer 88-00 D series would be to custom make your own mounts. If you have or know someone with a welder and decent fab skills then it shouldn't be that difficult. Another problem you will run into would be that the 97 tranny is hydro. Not sure if the 84-87 tranny will fit the newer D series motors, but you could always use a 88-91 Civic/CRX cable tranny. Only downside is it's a lot of work for only marginal gains.
A good swap would be a 1.6L DOHC 88-89 Integra motor/tranny. It is a more common swap for the 84-87 models. HASport makes a B series engine mount kit for your car so that is also an option as well.
Old Jul 8, 2004 | 01:51 PM
ravenous82's Avatar
I found that HASPORT makes the best engine swap motor mounts. A little expensive, but you want your motor to fit nice and snug, right? Hope it helps.
Joe Yaerrd
Jul 13, 2016 06:53 AM
fbpem1
Apr 28, 2006 03:03 PM
CALIdelsolSIR
Dec 3, 2005 07:54 PM
d15b
Jul 28, 2004 06:41 PM
civtegman
May 24, 2002 01:14 AM
