What cams gears for ls vtec?
Old 06-25-2004, 07:50 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default What cams gears for ls vtec?
Specs:Integra G2
B18b1 block not sure about head either itr head or gsr
jun 3 cams
rev valves
ctr pistons?
eagle rods
arp bolts
universal hks exhaust 2and1/2 pipeing
im thinking toda cam gears....
Modified by CrxStreetRacer at 3:09 PM 6/26/2004
Old 06-25-2004, 07:55 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: What cams gears for ls vtec? (CrxStreetRacer)
ttt
Old 06-25-2004, 08:15 PM
FastAllmotorLsVtec
Guest
Posts: n/a
bump
Old 06-25-2004, 11:03 PM
FastAllmotorLsVtec
Guest
Posts: n/a
bump for the nite!
Old 06-26-2004, 02:09 PM
FastAllmotorLsVtec
Guest
Posts: n/a
bump!
Old 06-26-2004, 02:14 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: What cams gears for ls vtec? (FastAllmotorLsVtec)
ttt
Old 06-26-2004, 03:53 PM
FastAllmotorLsVtec
Guest
Posts: n/a
bump
Old 06-26-2004, 03:57 PM
Turbogixxer's Avatar
All B-series cam gears are the same ( I dunno about b20a or b21a thou)
Old 06-26-2004, 03:59 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: What cams gears for ls vtec? (turbogixxer)
what are some good aftermarket ones?
Old 06-26-2004, 04:15 PM
Most of them are good gears, stay away from AEM gears, I do not like them. Had people bend valves cause the gears slipped on them.
Old 06-26-2004, 06:18 PM
SpoolnG2's Avatar
Skunk2
reasonably priced and has like 5 or 6 bolts to hold the gear in place. They wont slip. I'd run a higher c/r if your gonna run the JUN 3's . Get like a 12.5 to 1 CP or something.
Old 06-26-2004, 06:46 PM
FastAllmotorLsVtec
Guest
Posts: n/a
Default Re: What cams gears for ls vtec? (SpoolnG2)
ok so what should i get some pistons to higher my c/r can i get ib pistons?
http://store.ibspec.com/piston....html
Old 06-26-2004, 07:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastAllmotorLsVtec &raquo;</TD></TR><TR><TD CLASS="quote">ok so what should i get some pistons to higher my c/r can i get ib pistons?</TD></TR></TABLE>
IB spec pistons are good pistons. When selecting pistons and cams, you need to also see what intake and header you are going to run. You could just throw parts together and think that you are going to make as much HP as you can out of that set-up.
MatrixGSR
08-15-2010 12:06 PM
RIPED AIMAL
08-17-2009 08:12 PM
EF9status
04-27-2009 03:38 PM
SleepyHatchZ6
03-13-2009 02:53 PM
MysteryWagon
09-13-2007 05:20 PM
Quick Reply: What cams gears for ls vtec?
