h22 turbo on a 93 del sol....need some info...!
hey all....i was going thru the ads and saw a pretty decent 93 del sol for a pretty good price....before i call up the seller and work up a deal, can u guys help me out....? if i end up with that delsol, will the h22a motor fit in this car with enough room for turbo.....? pls help me out...ive tried so search but couldnt find what im really looking for....
1. with the h22a swap and the turbo...will i still be able to use the a/c? will there be enough room for the air conditioning....?
2. i already have the turbo kit at home and is jst sitting under my bed:drag gen3 for 97-01 ludes...i onlly want to boost 7-10...will there be a lot of modification done to the engine bay to fit the h22a motor with the drag kit? and again will i be able to use the a/c?
3. how much will i be looking at for a project like this....? not including the car....with jst the motor swap and turbo install...
pls help me out guys...im not very familiar with cars at all...ive tried to boost my car b4 but didnt work out and alot of people told me here to ask questions if i need help...pls help me out fellas...! thanks for your time reading my thread....any response will be appreciated...thanks again...!
Re: h22 turbo on a 93 del sol....need some info...! (GokuSs4)
1. highly unlikely
2. Drag kits need modification even when installed on the intended car, for sure there will be modification required when using it on the sol.
3. Check for motor prices, around 2K I think for the motor, turbo install price may very depending on the amount of fabrication required.
good luck
good luck
Re: h22 turbo on a 93 del sol....need some info...! (Del_Slowest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest »</TD></TR><TR><TD CLASS="quote">h22 won't handle boost</TD></TR></TABLE>
yes it will
yes it will
Yes turbo will fit on h22 in del sol, you just have to cut out some radiator support. And on low boost a stock h22 will handle it. Look how much room you got.
Alternator does not hit anything, I also have p/s in my h22 del sol:
A/C will be very hard to fit especially with a turbo, there is no room for the a/c condesor and the fan.
Also, I have a 98 H22A4/m2y4 full swap for sale. ( motor, trans,shifter, shift cables, ecu,wiring harness, and driver side inner c/v joint.)
Email me at teknotigger@aol.com for more info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest »</TD></TR><TR><TD CLASS="quote">when it cracks a ringland</TD></TR></TABLE>
did u experience this or something?
Re: h22 turbo on a 93 del sol....need some info...! (hondaZvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic »</TD></TR><TR><TD CLASS="quote">
did u experience this or something?</TD></TR></TABLE>
the h22 does have bad ringlands for boost. if you new anything about the h22 you should know this thats why there not a desired engine to boost, only if there built
Re: h22 turbo on a 93 del sol....need some info...! (crx2fast)
the way u guys are saying this.. yall make it sound as if u even put a turbo near a h22 its gonna freakin blow up.... c'mon.. anyone who knows anything knows u can only put a very conservative amount of boost on an h22(w/stock internals)/ otherwise u have to build the motor. *DUH*
and then what does this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2fast »</TD></TR><TR><TD CLASS="quote">
the h22 does have bad ringlands for boost. if you new anything about the h22 you should know this thats why there not a desired engine to boost, only if there built</TD></TR></TABLE>
have to do with this?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaZvic »</TD></TR><TR><TD CLASS="quote">
but to straighten things out... i thought this was a pointless statement.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest »</TD></TR><TR><TD CLASS="quote">h22 won't handle boost</TD></TR></TABLE> *stupid post*
which is what got me started in the first place.
zenon8890
02-27-2007 12:05 PM
