K20A swap into RSX BASE AUTO
OK, I have a 03 automatic base rsx. I bought a JDM K20A Type R Motor and I want to swap it into my car. It came with the entire motor, trans, ecu, axels, shift linkage, intake and exhaust manifold, and the engine harness. I realize that if I had a manual right now then this should theoretical go right in with no problem. But becuase I have an auto I think I may need more things like the pedal assembly, shifter (not sure what parts), and the reseviors for the clutch fluid and etc. Can someone please tell me what else I need or if I do need these things? Thanks.
Re: K20A swap into RSX BASE AUTO (nsted3)
thats all i think u need **** i have an 04 civic plan to swap k20a but need rsx or si axles and a bunch of other stuff ur setup is much easier if u dont swap i will buy motor off u
sounds like a lot of work.... and if you fukk up there goes an expencive car
i say sell the rsx, buy a 92 hatch and put the engine in... spend rest on a vacation, daily driver, save for house, or somethin'
or just sell it and buy a manual base rsx
