itr and ctr cams
Old Jun 29, 2004 | 07:31 PM
dornon13's Avatar
Default itr and ctr cams
i have heard that the ctr cams are the same as the itr but the itr intake is like 1 or 2 deg different...i guess my question is would it be worth it ( i assume itr would be more expensive) for the minor difference or would it be noticable?
Old Jul 6, 2004 | 02:30 PM
DSR!'s Avatar
Default Re: itr and ctr cams (dornon13)
The CTR Cams are almost the same as the ITR, the only difference would be the 3 degrees difference on the intake side which increases the air flow in the CTR Cams. The Exhaust cams on the CTR is the same as the ITR's though
Old Jul 15, 2004 | 09:46 AM
dornon13's Avatar
Default Re: itr and ctr cams (DSR!)
are you saying that CTR cams would actually be better?
Old Jul 15, 2004 | 09:01 PM
Redline130's Avatar
Unless you have parts that will support and work in conjunction with the cams, neither would be better. I'm not saying that these cams are radically different from stock B16 or GSR cams, but they will give you better gains if you can help them with improving the efficiency of the airflow through the motor. If you have a stock motor, I wouldn't expect too big of a gain in HP to the wheels with just the cams alone.
Old Jul 17, 2004 | 08:45 AM
dornon13's Avatar
Default Re: itr and ctr cams (Redline130)
well i am doing a big build so i was just wondering but i will prolly just get better afttermarket cams
Old Jul 17, 2004 | 11:48 AM
accorse07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">well i am doing a big build so i was just wondering but i will prolly just get better afttermarket cams</TD></TR></TABLE>
if your doing a big build forget the oem cams and go with aftermarket ones.
99fbpem1
May 1, 2009 09:22 AM
crackerjacker006
Aug 23, 2005 11:05 PM
kenepo_vtec
Jul 4, 2004 08:57 PM
498GSR
Oct 28, 2002 10:06 PM
EJ8 Kenobi
Oct 23, 2002 05:01 PM
