jdm b16a2?
Old Jul 3, 2004 | 03:11 PM
redboost10's Avatar
Default jdm b16a2?
i was told a jdm b16a2 will hook right up to a 99 civic si. the si is obd2b and i thought the jdm b16a2 was obd1. before i buy this motor i was wondering if someone can help me out here. will it hook up to the 99 si harness
Old Jul 3, 2004 | 03:19 PM
Turbogixxer's Avatar
Default Re: jdm b16a2? (tgh99si)
There is no such thing as a JDM b16a2. B16a2 is found in USDM 99-00 SI. You can get a OBD2 B16a and it will bolt up and clip up besides the Vtec pressure switch. You will have to run a 99-00 SI ECU or a convertion harnes to OBD1 and run a OBD1 ECU.
Old Jul 3, 2004 | 06:08 PM
redboost10's Avatar
Default Re: jdm b16a2? (turbogixxer)
so if i buy a jdm b16 obd2, it will not work unless i use a obd1 ecu? but the distributor, injectors and all that will plug right in?
Old Jul 3, 2004 | 07:02 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">so if i buy a jdm b16 obd2, it will not work unless i use a obd1 ecu? but the distributor, injectors and all that will plug right in?</TD></TR></TABLE>
reread his post.
Smoak
Jan 29, 2007 03:19 PM
redEH2
Aug 20, 2005 03:22 PM
Coppertop
Jun 20, 2005 08:13 AM
civic99keith
12
Mar 17, 2004 07:12 PM
SC61HB
Feb 1, 2003 08:15 PM
