C.E.L. need help ASAP please
Old Jul 2, 2004 | 03:12 PM
Azntwins's Avatar
Default C.E.L. need help ASAP please
I Did a b18c1 swap in my 97 civic dx and i got these 3 codes. P0450 evap emission control system pres sensor fault. And P0453 evap emission control system pres sensor high and P0133 primary HO2S (O2 Sensor) Slow Response (Sensor 1) Can someone help me fix these problems? Thanks
Old Jul 3, 2004 | 09:42 AM
all_stock's Avatar
Default Re: C.E.L. need help ASAP please (Azntwins)
i think the evap code might be your evap purge solenide check the wiring on that one or even the charcol canister. also make sure youir gas cap is tight you will throw a evap code from that. also check the wiring on the o2 sensor
Old Jul 8, 2004 | 03:57 PM
Azntwins's Avatar
Default Re: C.E.L. need help ASAP please (all_stock)
ok thanks, its not my gas cap thats the 1st thing i checked, and how does the charcol canister look like/located? Will a o2 sensor from a 97 civic dx work on a 97 gsr motor? Also the o2 sensor didnt reach so i had to extend the wire to make it reach. Is there any other way to do this besides cutting a splicing the wires? Thanks.
Old Jul 8, 2004 | 10:31 PM
97mini-me's Avatar
I put a charcoal canister out of a civic ex in mine. It's the same thing as the one in the si. The dx one is a two way, the others are three. Don't ask me what that means, I just saw that they were different and hooked them up. The ex one I have also has a sensor located on the top of the canister, unlike the dx which doesn't have a sensor on it. As far as the o2, I used posi-lock connectors on mine to extend the wires and it works fine. I don't know if the dx is compatible with the gsr though.
1997civichx
Engine Management and Tuning
Dec 30, 2014 01:37 PM
S2KILLA
Jul 7, 2010 08:30 AM
d's slow eg
May 5, 2010 10:28 PM
junior_tm
May 7, 2009 09:46 PM
DC4RS Integra
Feb 12, 2008 09:28 AM
