ODB0 Integra LS Distributor Wiring Questions - Help.
I'm trying to use an ODB0 LS distributor with my ODB1 Civic EX engine harness. Obvisouly, the the plugs do not match. I have cut the ODB0 connector plug off, and have attached an ODB1 connector plug by matching the wire colors. However, there are 2 white wires that do not match up from the distributor to the plug. I have tried switching the wires, but get no spark either way.
Any ideas? Could it have something to do with the wiring .... or perhaps the distributor is bad? It's an LS Engine by the way.
Vadian
02-02-2002 07:58 PM
color, connector, connectors, diagram, distributor, distrubitor, dizzy, honda, integra, ls, odb0, odb1, order, wire, wiring
