Perfect pistons for B20/VTEC...
I have read and searched. If you can't help me please don't reply, just let the post pass by and forget about it.
Anyways, I was curious to those that have experience with CRVTEC's; is there a piston that can be installed in the B20 short block so that the valve reliefs do not have to be modified?
I have a 94' Sir-II top end, and am contemplating on getting a local B20Z. This will be mated with the trans that came off the same Sir-II. This will be my first complete tear down and rebuild type swap. I really just want to make it easy as possible.
Thanks for any possible help.
Re: Perfect pistons for B20/VTEC... (africanqueen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by africanqueen »</TD></TR><TR><TD CLASS="quote">I think Arias pistons make some for the B20. I am going to have to get some too very soon. </TD></TR></TABLE>
So do you have valve clearance issues? From all that I have read the OEM B20 valve reliefs on the pistons are not large enough for the valves from a VTEC to clear during engine operation. I just thought maybe the powers that be would have given us rookies a quick answer.
How do you like the CRVTEC?
Re: Perfect pistons for B20/VTEC... (B_Something)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_Something »</TD></TR><TR><TD CLASS="quote">
How do you like the CRVTEC?</TD></TR></TABLE>
I think the clearance is fine. No problems whatso-ever. I use my car as a daily driver and I love it. If the swap is done correctly and you notch the pistons, everything will run smoothe. I would recommend this swap to everyone.
Yeah I have had various swaps, not that on yet. I think I would like a little shot of torque! Did you perform the swap or have it done? What ecu are you runnng?
The B20B/Z intake valves are 31mm.
Vtec valves are 33mm.
So the the vtec vales will not clear the valve pockets in the stock pistons.
On mild cams this isn't an issue. Cams with greater lift cause a problem.
FYI If you deck the block or mill the head the problem is further exaggerated.
It involves taking a dremel to the valve seats and opening them up a couple mm. I've never seen a how to article done on it.
If you do it you want to keep the valve openings symetrical and smooth as possible. Note this work will slightly reduce compression as you are decreasing the volume of the piston.
Personally I wouldn't do this mod, but if you are running high lift cams and stock B20Z pistons you'll need to.
Re: Perfect pistons for B20/VTEC... (Veris)
Yeah I'm not real interested in grinding away at my pistons. That's why I am looking for a proven drop-in replacement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B_Something »</TD></TR><TR><TD CLASS="quote">Yeah I have had various swaps, not that on yet. I think I would like a little shot of torque! Did you perform the swap or have it done? What ecu are you runnng?</TD></TR></TABLE>
Rage Performance did the swap. I thank them for doing a swell job on my car. Everything runs Perfect. As for the ECU, I am running the JDM GSR.
Re: Perfect pistons for B20/VTEC... (99Civb20)
hey whats up man, I just wanted to pass along my dyno of my old b20vtec setup
b20z bottom, I opened up the valve releifs (though you DONT need to with ITR cams and stock cam timing)
B16 head
ITR cams(stock valvetrain)
ITR intake manafold
ITR throttle body
untuned stock OBD1 b16 ECU
adj FPR to add the needed fuel
Was a lot of fun to drive, still runs great today even though I sold the motor to a friend.
Not a bad daily driver
let me know what other questions you have
give me a call on monday, ill walk you through all your b20vtec questions
B16 head
ITR intake manafold
ITR throttle body
Re: (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE »</TD></TR><TR><TD CLASS="quote">topline p30's?</TD></TR></TABLE>
84mm bore yo
84mm bore yo
sorry bout that. i thought camp 1320 had a batch made but i went back and looked and i guess every1 flaked out or something. find 99 more people and u can have a set made.
https://honda-tech.com/zerothread?id=631970
Re: (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE »</TD></TR><TR><TD CLASS="quote">sorry bout that. i thought camp 1320 had a batch made but i went back and looked and i guess every1 flaked out or something. find 99 more people and u can have a set made.
https://honda-tech.com/zerothread?id=631970</TD></TR></TABLE>
yah you need a lot more people
boblaw
02-24-2008 08:49 AM
JDM97EK
14
03-07-2006 07:44 PM
