OBDII GSR swap into 5G Civic Wiring Question
What is needed in order to make this happen? I have a OBDII GSR w/ the OBDII wiring harness. It's going into a 92 Civic CX. I heard that all the 92 Civics had the same wiring as the SOHC VTEC wiring found in the Si & EX models. But when I crank it over nothing happens. The starter isn't even cranking. Is there wires or pins that need to be swapped? Thanks for your help.
Joe
Joe
Re: OBDII GSR swap into 5G Civic Wiring Question (joestud)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joestud »</TD></TR><TR><TD CLASS="quote">It's going into a 92 Civic CX. I heard that all the 92 Civics had the same wiring as the SOHC VTEC wiring found in the Si & EX models.</TD></TR></TABLE>
Cabin harnesses are the same, so it is prewired for Vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joestud »</TD></TR><TR><TD CLASS="quote">The starter isn't even cranking. Is there wires or pins that need to be swapped? Thanks for your help.</TD></TR></TABLE>
No pins need to be swapped. It sounds like you have a problems with your grounds.
Grounds:
Thermostat
Transmission
Valve Cover
Grounds:
Thermostat
Transmission
Valve Cover
Re: OBDII GSR swap into 5G Civic Wiring Question (turbogixxer)
I checked all the grounds. Is there a possibilty that the P05 stock CX ecu will not start a GSR Swap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joestud »</TD></TR><TR><TD CLASS="quote">Is there a possibilty that the P05 stock CX ecu will not start a GSR Swap?</TD></TR></TABLE>
It will start and run the car (under low loads) with no problems (besides a CEL for 02).
You check you have power going to the starter and the S-terminal?
Cynical 1
10-05-2003 11:14 AM
Integra_Boi
10
10-03-2003 05:47 PM
lonefuzzy79
07-21-2002 09:29 AM
