H23vtec build plans.....
well i'm currently getting ready to start purchase things for my h23vtec build at the end of feb.i'm looking for opinions on my desired setup as of right now, and would like to know what you think i should change if anything.my plans are to have a streetable race car, i will first do everything to complete the vtec conversion,build the bottom end FOR TURBO, drop the motor in and run it as is until i have money to get the turbo.i want to go ahead and build low compression and whatnot for the turbo app even tho i will be turbo-less at the beginning, i just dont want to build n/a now then rebuild later this year for f/i.
as of right now, after completing the vtec conversion, i will be going with the following for my setup.
(this is kind of the order also)
-H22 tranny
-CP Pistons 9:1 C/R
-Eagle H Beam Steel Rods OR Crower Econo Billet Rods ---WHICH??
-Sleeves -- Yet to be determined
-Piston rings -- WHAT KIND??
-Flywheel/Clutch
what else am i gonna need?my block is tore down to the bare block right now....any suggestions and help is great, thanks in advance
(yes i've searched and read many things)
-H22 tranny
-CP Pistons 9:1 C/R
-Flywheel/Clutch
Re: (hOndafienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 »</TD></TR><TR><TD CLASS="quote">with forged pistons in any h series you must sleeve because of frm</TD></TR></TABLE>
Whats frm?
Whats frm?
