B18c1 in 99 EK.....right mounts??
I have a few more questions about this swap im about to do.
On the rear mount/bracket I use:
99-00 Si Rear Bracket
96-00 Stock Civic Mount
On the drivers side I use:
99-00 Si Bracket
Is that correct??
also, if i get ES motor mount inserts, which kit should i get??
thanks
chris
99-00 Si Bracket
Is that correct??
thanks
chris
Re: B18c1 in 99 EK.....right mounts?? (jdmstreethatch)
yea you got it right.......I have the prothane kit and it works wonders, and also it wouldnt hurt to get the torque mount insert set also.
Re: B18c1 in 99 EK.....right mounts?? (5-lugHatch)
civic mounts and also something I ended up being screwed on was I needed a coolant hose that was different for the gsr motor (compared to r/ls) which i never see mentioned acura part # 79725-st7-a01
Re: (jdmstreethatch)
okay im about to order the mounts tomarrow from honda if i can get a clear answer as to what i actually need.
correct me if im wrong or if i forgot something, i NEED:
#10 -- Pass. Side Tranny Bracket
# 7 -- Rear "T" Bracket
now, which part do i need on the drivers side?? there are Three pieces there, the top bracket piece, the middle rubber mount piece (#5), and the bottom bracket (#E-14-1). I need to know which one to order.
Is this all i need as far as mounts/brackets go??
depending on what the honda dealership gives you as a price HASPORT makes a 99 civic conversion to B18c1.
you use the big round gsR mount on the motor and they have a bracket that bolts in where that funky pyrimid civic chassis mount goes and it will accept the big round gsr motor mount, from what i understand it is super strong and makes the world of difference in the EK chassis.
i bet its cheaper then all the honda ****, plus you can use theone that came with the motor.
i always broke the drivers side motor mount in my 99si, i broke 4 of them, only at 300hp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstreethatch »</TD></TR><TR><TD CLASS="quote">which number for the drivers side.
and the manual trans bracket your talkin about is #10 right?</TD></TR></TABLE>
Doing the same thing. Anybody know what numbers
well the hasport kit is like $450!!!!!! I think i only need to order two parts from honda right now. I wish someone that has actually done the swap would comment.
well i found out something interesting. the driver side mount has the EXACT same part number for both the Si and CX/DX models.
the only diffrence is the E-14-1 bracket in the pic, on the cx/dx it has a diffrent part number. but i dont know why it would be diffrent if the drivers side mount is the same??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstreethatch »</TD></TR><TR><TD CLASS="quote">well i found out something interesting. the driver side mount has the EXACT same part number for both the Si and CX/DX models.
the only diffrence is the E-14-1 bracket in the pic, on the cx/dx it has a diffrent part number. but i dont know why it would be diffrent if the drivers side mount is the same??</TD></TR></TABLE>
You need the E-14-1 Bracket, and then you have to remove your studs from the old bracket and reuse them on the new one.
I just did this yesterday, when you try to put the Dseries bracket in the B motor it wont line up with the 3 holes in the motor.
oh yeah, and anyone else thats confused about what you need wiht this swap here is a great article:
http://www.phear7imports.net/trey/6gen/
scroll down a little and it has the part number of the mounts we need.
You can buy that part from hondaautomotiveparts.com
All you have to do is search part number, put it in, and then you can add it to your cart.
I ordered mine from them.
98vsmferio
05-29-2005 09:16 PM
GeekinEK
11-21-2004 10:41 AM
