B18a in 91 civic......need help!!!
I Just finish putting ob0 B18a in my 91 civic si .. and the idle is really jumpy when its warms up and its not throwing any codes ... i wus thinking it wus the fast idle valve but i am not certain . and im kinda lost on what i should do next so any input would be greatly apprecaited
Re: B18a in 91 civic......need help!!! (88fgfd)
clean your iacv, disassemble your fitv and bottom out the screw, bleed your cooling system, and make sure you don't have any vacuum leaks.
Re: B18a in 91 civic......need help!!! (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 »</TD></TR><TR><TD CLASS="quote">clean your iacv, disassemble your fitv and bottom out the screw, bleed your cooling system, and make sure you don't have any vacuum leaks.</TD></TR></TABLE>
Yup, that about sums it up
giff74
03-15-2004 10:58 AM
