96-98 Hasport motor mount for a b-18c1 swap
When you use this mount, which block side mount do you use? GSR or the 99 SI Block side mount, the one that bolts to the engine block?
Re: 96-98 Hasport motor mount for a b-18c1 swap (97civicdx)
If you are putting this into a 96-2000 Civic, you need the block mount from a 99-2000 Civic Si..
