P30 VAFC II wiring...need help.
Ok, I did a search and came up with http://www.jrponline.com and they had a good diagram on there. I also went to http://www.apexi-usa.com and looked at what they had. I have seen variations b/w both sites in the pin outs on the ECU. I also have 2 documents that I used.
1 was for the P61 ECU (92-93 GSR), and the other a P30
P30_OBD1
A1 BRN INJ1 INJ1
A2 YEL INJ4 INJ4
A3 RED INJ2 INJ2
A4 ORN/WHT VTS VTEC solenoid
A5 LT BLU INJ3 INJ3
A6 ORN/BLK PO2SHTC O2 sensor (heating element)
A7 GRN/YEL FLR1 fuel pump
A8 (empty)
A9 GRN/WHT IACV IAC valve
A10 (empty)
A11 (empty)
A12 YEL/GRN FANC Fan Output
A13 GRN/ORN MIL MIL (check engine light)
A14 (empty)
A15 BLK/RED ACC (a/c compressor clutch)
A16 WHT/YEL ALT C alternator
A17
A18 (empty)
A19 (a/t trans only)
A20 RED PCS EVAP purge control solenoid
A21 RED/GRN ICM ICM
A22 (empty)
A23 BLK PG1 ground
A24 BLK PG2 ground
A25 YEL/BLK IGP2 to main relay and to gound for o
A26 BRN/BLK LG1 gound
B1 YEL/BLK IGP2 to pin A25
B2 BRN/BLK LG2 ground to shields for CYP & TDC
B3 (a/t trans only)
B4 (a/t trans only)
B5 BLU/RED ACS a/c switch
B6 (empty)
B7 (a/t trans only)
B8 BRN/RED PSPSW PSP switch
B9 BLU/WHT clutch interlock switch
B10 YEL/BLU VSS vehicle speed sensor
B11 ORN CYP P CYP -P
B12 WHT CYP M CYP -M
B13 ORN/BLU TDC P TDC -P
B14 WHT/BLU TDC M TDC -M
B15 BLU/GRN CKP P CKP -P
B16 BLU/YEL CKP M CKP -M
D1 WHT/BLU VBU Back Up Power
D2 GRN/WHT BKSW brake switch
D3 KS Knock Sensor
D4 BRN SCS service check connector
D5 (empty)
D6 ORN/BLU VTM VTEC pressure switch
D7 LT BLU TXD/RXD (data link connector)
D8 (empty)
D9 PNK ALT F alternator
D10 GRN/RED ELD electric load detector
D11 RED/BLU TPS TPS Signal
D12 YEL/GRN
D13 RED/WHT ECT ECT sensor
D14 WHT PHO2S O2 sensor
D15 RED/YEL IAT IAT sensor
D16 WHT/YEL VREF VREF
D17 WHT MAP Map Signal
D18 (a/t trans only)
D19 YEL/GRN VCC1 MAP 5V
D20 YEL/WHT VCC2 TPS 5V
D21 GRN/BLU SG1 MAP GND
D22 GRN/WHT SG2 TPS GND
I drew out the connector on the ECU and labeled all of the appropriate pins that it says to wire up the VAFC to. However, the jrponline diagram showed a loop that needed to be made with the pressure signal input and output and the VTEC solenoid signal input and output. My question is, do I just wire it up to the appropriate pins as indicated on JRP and APEXi's site, or do I find the appropriate pins to wire up the pressure signal and vtec signals? Posted this in Integra forum as well...Thanks for any help given.
P30_OBD1
A1 BRN INJ1 INJ1
A2 YEL INJ4 INJ4
A3 RED INJ2 INJ2
A5 LT BLU INJ3 INJ3
A8 (empty)
A10 (empty)
A11 (empty)
A14 (empty)
A17
A18 (empty)
A21 RED/GRN ICM ICM
A22 (empty)
A23 BLK PG1 ground
A24 BLK PG2 ground
B3 (a/t trans only)
B4 (a/t trans only)
B6 (empty)
B7 (a/t trans only)
D3 KS Knock Sensor
D5 (empty)
D8 (empty)
D12 YEL/GRN
