b16a into crx with obd1 conversion PROBLEMS!!!
ok i swaped in a b16a into my friends 91hf i used an obd0 to obd1 conversion harness, a chipped p28 ecu with the p30 maps on it, i installed ctr cams, a new obd1 dizzy and a 4 wire o2 sensor. i adjuted the timing with the service conector jumped and got it on the red line on the crank pulley. it starts up fine first try everytime, but when we try to drive it it sputters BADLY it is basically undriveable. no CEL no codes. im stuck everything is in order and it should work fine. did i fubar the cam install, would this cause the symptoms i described? PLEASE HELP!!!!
88MonsterSi
Engine Management and Tuning
08-10-2009 07:41 PM
rextec
24
02-13-2005 04:20 PM
