b18c into 94 teg...
b18c into 94 teg...
Going back in tonight with a JDM R Swap into a 94 GSR. Running the OBD1 GSR ECU set up with Hondata and flashed with an R base map to get it to the dyno. GSR OBD1 Wiring Harness. OBD 1 distributor and alt. Swapping over the injector clips to run the OBD2 style injectors as they are new...forgetting anything?
