J35 engine + TL 6speed Manual Tranny.... is this possible?
Go Tigers!
hey guys i was doing some research and does anyone know if J-series motors are swappable with J-series trannys? TIA
Re: J35 engine + TL 6speed Manual Tranny.... is this possible? (bense)
If you made yourself some mounts, custom axles and a bunch of other **** then i bet it would be possible.
Go Tigers!
Re: J35 engine + TL 6speed Manual Tranny.... is this possible? (delLudeVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC »</TD></TR><TR><TD CLASS="quote">If you made yourself some mounts, custom axles and a bunch of other **** then i bet it would be possible.</TD></TR></TABLE>
That's not the question here. I'm asking if the transmission bolts up to the motor.
sooo your asking if a j motor bolts up to a j tranny? thats like asking if a b series tranny bolts up to a b series motor.
Go Tigers!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC »</TD></TR><TR><TD CLASS="quote">sooo your asking if a j motor bolts up to a j tranny? thats like asking if a b series tranny bolts up to a b series motor.</TD></TR></TABLE>
or asking a s2000 (f-series) bolts up to an accord f-series tranny
Re: J35 engine + TL 6speed Manual Tranny.... is this possible? (xparkesx)
YES IT WILL FIT!!!! you can put an odessey tranny with an accord motor or pilot engine or whatever. all of the 3.0 3.5 v-6 are the same engines and trannies except for the pilot of course because i has a rear out put. And yah you can take and s-2000 f23a and put it a acccord or civic and a H or an F tranny will bolt to it. But try and buy one of those $$$$$
Re: J35 engine + TL 6speed Manual Tranny.... is this possible? (roadkillcrxsi)
oh the 2.7 is the only odd ball v-6... that was a chapter in hondas past i would like to forget
turboedsupe
11-02-2008 10:08 PM
