looking for a harness for a 98 GSR into a 93 Civic Si
what harness is used for the engine?
is it the 98 GSR motor harness and plugged into the 93Si harness
or is it the harness from the 93 1.6 motor
I am looking for a mint uncut harness of whicever i need
Re: looking for a harness for a 98 GSR into a 93 Civic Si (555R)
I have a couple of GSR engine harnesses that will plug right in. Make me an offer on them. PPPpartsp3@cs.com
Re: looking for a harness for a 98 GSR into a 93 Civic Si (PrecisionPerformanceParts)
well what are you asking for the harnesses
I am not about to play the offer game here anymore
HT has given me a huge headache recently
I'm doing the same swap, but you can use your stock one if you feel comfy with some wiring, or get obd1 items like dizzy injectors and alternator.. good luck
jst eep everuthong from the gsr swap injection and harness, and plug into the civic body
like you put it back in the teg.
use obd1 computer
add knock sensor and iac if you fond obd1 gsr ecu and you are done.. isn'nt honda great?
use obd1 computer
92GSRHB
01-31-2009 05:09 PM
