B20B into eg: 0BD2>OBD1 conversion harness?
hey guys, if i have a B20b and an OBD2 LS wiring harness, is there a conversion harness i can buy to plug into my OBD1 P75 ecu? im not sure if any company makes them, just trying to avoid buying all OBD1 electronics. i'd rather have this thing be all plug and play. thanks for any help, jeff
Re: B20B into eg: 0BD2>OBD1 conversion harness? (Lambo123)
In an EG you have 2 main harnesses - engine and cabin. The OBD1 P75 ECU will plug directly into your cabin harness under the dash (ECU plugs). If you use an OBD2 Integra engine harness this will also be plug and play with the cabin harness side plugs under the hood at the shock towers. There will be no need for any OBD conversion harnesses or any reason to buy OBD1 distributor, injectors, etc. That's why EG's are a swapper's gift from God!
