OBDII B series into EG hatch
Re: OBDII B series into EG hatch (92Lx)
If i remember correctly your distributor, injectors, alternator and 2 o2 sensors vs 1 was the main difference from obd1 to obd2.. hope your gonna use obd1 p72 ecu or chipped p28 for simplicity... i may have miss the little stuff but those were the main ones i remember.... since i have a obd2A gsr going in my 92 si..... good luck...
You can drop the full OBD2 swap into a 92-95 EG chassis, use the OBD2 Integra engine harness and an OBD1 ECU and it's nearly all plug and play. Like my 92 VX for example: 99 B18C1 swap with all OBD2 components and engine harness running off a 95 P72 GSR ECU. It's been running for over 4 years now in various forms, boosted, N/A blah blah and I've never had any issues.
beginmyhonda
01-11-2010 05:02 PM
zamboolicious
02-06-2008 05:44 PM
