turbo gsr
Re: turbo gsr (numbnuts22715)
man, you don't know what your missing. i believe the IAB kicks around that time on a stock ecu. just get uberdata and a wideband, put your vtec down to like 5000 rpm and enjoy.
Re: turbo gsr (1981juice)
Sounds to me like the ECU is in limp mode. Before you go running the car it would be best to check for CEL's if the check engine light is on first off. From there if that's not an issue then it's probably fuel delivery or lack of, timing or spark. It's hard to say because I don't know what all has been done to the car.
Re: turbo gsr (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">Sounds to me like the ECU is in limp mode. Before you go running the car it would be best to check for CEL's if the check engine light is on first off. From there if that's not an issue then it's probably fuel delivery or lack of, timing or spark. It's hard to say because I don't know what all has been done to the car.</TD></TR></TABLE>
This man knows what he is talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kine462 »</TD></TR><TR><TD CLASS="quote">man, you don't know what your missing. i believe the IAB kicks around that time on a stock ecu. just get uberdata and a wideband, put your vtec down to like 5000 rpm and enjoy. </TD></TR></TABLE>
Please tell me the original poster isn't running this thing on an fmu.
Ls4thGen
05-22-2005 06:59 PM
