OBD1 Conversion harness, which dizzy?
Old Feb 10, 2005 | 05:42 PM
JMod's Avatar
Default OBD1 Conversion harness, which dizzy?
Alright, i have a 96 hatch that i'm puttin a b20/vtec motor into. The motor is obd2, but i'm going to be running an obd2a to obd1 conversion harness so I can run a chipped p28 ecu. Now with the harness do I have to use an obd1 dizzy? or can I use my dizzy that i have now?
Old Feb 10, 2005 | 07:19 PM
locash's Avatar
Default Re: OBD1 Conversion harness, which dizzy? (JMod)
You can use either an obd1 or obd2 distributor, the internal electronics are compatible..
Old Feb 11, 2005 | 04:43 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMod &raquo;</TD></TR><TR><TD CLASS="quote">Now with the harness do I have to use an obd1 dizzy? or can I use my dizzy that i have now?</TD></TR></TABLE>
Like locash said, the OBD1 and OBD2 are internally the same, only the plugs are different. I would use the OBD2 dizzy that you have now since it's plug and play.
Old Feb 13, 2005 | 10:58 AM
JMod's Avatar
Default Re: OBD1 Conversion harness, which dizzy? (VTECVillain)
alright, thanks. Just wanted to make sure I could still use the obd2 dizzy I have, it'll make it alot easier.
efrunner09
10
Sep 21, 2009 02:57 PM
jo7man4
Jun 15, 2009 11:33 AM
Hybrid
Jan 13, 2004 07:09 PM
. o 69 o .
Aug 28, 2003 11:51 AM
Nikos
Jul 3, 2003 08:22 AM
