01 itr brakes in 95 civic
i know its the wrong forum BUT do i get a itr porportioning valve or a gsr or an older integra w.o abs, considering my civic doesnt have it
along w. the itr master and booster .....
Re: 01 itr brakes in 95 civic (Gsr_Hybrid_theory)
Before people are not nice to you, I'd suggest rousing through the Hybrid forums...
https://honda-tech.com/zeroforum?id=18.
Good luck, bro.
Brandon
Good luck, bro.
Brandon
Re: 01 itr brakes in 95 civic (Haleiwa-Brando)
Hint:
Spell proportioning right, and your search results will be from smart people.
» Search Results
Your search for proportioning returned 160 results.
Your search for itr proportioning returned 9 results.
Yeah, those search results mostly suck. Someone suggests 99-00 Si without ABS, or JDM ITR without ABS (?)
Your search for itr prop valve returned 6 results.
Here's a good two:
https://honda-tech.com/zerothread?id=557916
https://honda-tech.com/zerothread?id=870927
Maybe 94-01 Integra RS w/o ABS is a good choice.
» Search Results
Here's a good two:
Your question is better suited for the hybrid and or civic forum. You can also try the search function which returned various results for me under various other forums (namely hybrid and civic).
It would also help if you mention the model of civic you have and if you have rear drums or disks.
Re: 01 itr brakes in 95 civic (KayOs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs »</TD></TR><TR><TD CLASS="quote">Your question is better suited for the hybrid and or civic forum. You can also try the search function which returned various results for me under various other forums (namely hybrid and civic).
It would also help if you mention the model of civic you have and if you have rear drums or disks. </TD></TR></TABLE>
Well, yeah, but you suck at t3h reading.
He has 01 ITR brakes swapped in, master cyl and brake booster, but no ABS. His Cibic doesn't have abs, so what does that make it, cx/vx?
DerangedEG
02-27-2004 12:15 PM
