NA B20 info needed / advice
looking for some tech info about n/a b20 setups ... non vtec
i need to know if my RC 310s are a good choice to use for the B20
also should i use my new gsr water / oil pump on the b20? or just use the ones that come with the swap
Re: NA B20 info needed / advice (2NR0066)
its good you are researching before commitin.
1) you need a dohc vtec o & w pump because the non vtec motors do not suplly enough pressure or quantity at elevated rpms.
2) dohc vtec motors have oil squirters in the bottom end to assist with oiling; b20/18b dont. hope this helps bro!
Re: NA B20 info needed / advice (BigHeadKid)
It's too bad people can't give out the right info though..
The oil pump on the 97-00 CRV B20B/Z is the same exact part as on all 96+ Integra's, whether it be VTEC or not. FYI - OEM Honda Part number 15100-P72-A01
So, regardless of what some people think, you can keep your stock B20B/Z oil pump.
Also, if you are going to keep the b20 n/a and non-vtec, don't bother with the vtec water pump..
Re: NA B20 info needed / advice (locash)
(Sorry for hijacking) So basically, if you get a 97+ CRV motor in a 97+ integra, it fits straight in?
Re: NA B20 info needed / advice (CompanyFlow)
yes, it's a straight swap. you can use your ecu. your lucky all my friends have older cars and we have to modify the distributor. the crv one will plug to your car.
