header clearance in h22 eg
im planning on swapping a h22 into my 92 cx , my question is how low does the header sit below the car? just asking because im a firm believer in " if you cant drag it your a ******" and like my car low. and i dont wanna beat the header to crap and have to replace it every few months or so.
also has ne one bought a complete wire harness from hasport? does it basically make the wiring a "plug and play" mod or not. cuz the bolting the motor in and cutting for the shifter cable i feel comfortable doing , just not really big on wiring.
or if anyone can help me / answer my q's id appreciate it for eva.
oh f%%% dodge trucks. mainly big green ones with ghost flames.
Ditto
Re: header clearance in h22 eg (mle_92cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mle_92cx »</TD></TR><TR><TD CLASS="quote">because im a firm believer in " if you cant drag it your a ******" and like my car low. </TD></TR></TABLE>
Umm, your a ******... get a S10 and go drag your frame across the highways
Re: header clearance in h22 eg (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter »</TD></TR><TR><TD CLASS="quote">
Umm, your a ******... get a S10 and go drag your frame across the highways </TD></TR></TABLE>
Damn right H22 is the worst for ground clearance should've stuck with your d-series
Guest
Posts: n/a
This header has about as much as you can get.And also makes big power.
http://www.importpowerhouse.co...s.htm
Hasport does make the harness pretty much a plug and play job. Ive never used it on a h swap but used it on a b series in a ef hatch. All i had to do was pin in a couple wires simple. But turbo gixxer on here made my harness for my h swap and the quality was great i suggest you shot him a pm and see what he says
Brian
Brian
Re: (soon2b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">" if you cant drag it your a ******"</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">DONT ACT LIKE ITS YOUR FIRST TIME!!!!!!!!!!!!!</TD></TR></TABLE>
Just like your sig says, why do you post like it's your first time?
Re: header clearance in h22 eg (1SICJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SICJDM »</TD></TR><TR><TD CLASS="quote">
This is at the track though. I was onslicks at 7psi...</TD></TR></TABLE>
Wow, that is almost a silly height! What size you use?
I'm using 22x8x13, car is lowered 1.3", and it's nowhere close to hitting the ground.
Re: header clearance in h22 eg (cpforyou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpforyou »</TD></TR><TR><TD CLASS="quote">
I'm using 22x8x13, car is lowered 1.3", and it's nowhere close to hitting the ground.</TD></TR></TABLE>
I'm also running a 22x8x13 , and by the looks of the pic i'm close to the ground as well. My imagine engineer header hangs about a inch lower than my oil pan. Even when I lift my car bigfoot style , I still manage to scrap on the uneven parts of the track. I wish I wouldve went with a 15" rim or maybe a 24" tire. I'm almost done collecting parts for my turbo setup so I might just upgrade the tires anyways.
Re: header clearance in h22 eg (93hatched_projekt)
damn you guys have low *** cars ****...i drive around with my header no problems with out scraping (knock on wood) just dont slam your car
Re: header clearance in h22 eg (7926)
I'm not too low. I've hit my pan a few times though. I'm on my 2nd one but the mine came with was kinda beat up in had a couple little holes. Around here I can't be any lower, sometime there isn't even road so ... the roads just suck.
That **** is low with the slicks, I've never had mine on my 22x8x13 slicks yet. I might need to see how well its going to work. 1.75"-2" drop in the front so I don't think it'll be bad.
VtecKiDD
102
01-07-2009 07:38 PM
