95 gsr swap into a 91 ls?
Hey im really tired from last night lol and am putting a 95 gsr motor into my 91 ls integra. What do you i need to do? Which wiring harness do i use and stuff. Need to find some answers asap.......please help me out so i could finish this guys thanks
Re: 95 gsr swap into a 91 ls? (ITR.#1446)
First thing to address is the hydro tranny situation. I've never heard of anyone putting a hydro tranny in a DA integra but there could be some kind of mount kit that I havnt seen. I'm assuming there isnt such a kit so you going to have to run a Cable tranny. I'm not good with tranny code but you have a choice from b16 and ls tranny. Older b16 trannys and ls trannys 90-91 integra run a small input shaft. So you would have to run a clutch designed for this.92-93 ls trannys and b16 tranny from xsi integra from japan run a big input so you would run a hydro tranny clutch setup.
For wiring use 90-91 integra harness and run the extra wire for vtec. You will also have to source a obd0 dizzy from older b16 or you can just buy a brand new one from distrubutor king.
Axles 90-93 integra with 90-93 half shaft.
Ecu you can run a pr3 or you can buy a conversion harness to convert to obd1 and run the ecu that should have came with the swap and the original dizzy from the motor also.
For mounts just run the stock 90-93 mounts.
That should cover just about everything. If not do a search.
Hope everything works out
payneth
10-29-2005 12:39 PM
