Map Sensor Help On a B18B Swap in to CRX Si
I have a question concerning the map sensor on the throttle body, I am swaping in a b18b into my CRX si i have rewire all the wires and need help with the map sensor on the b18b..Should I use the map sensor on the throttle body and rewire a 94-95 integrra map senor plug to make it fit, or use a 90-93 integra throttle body with a map sensor that will just plug right up to my crx Si harness, or can I just put the map sensor from the 90-93 integra and use the b18b throttle body, anyone who have done this swap please give me some advice, I have tried searching and I came up with alot of swap issues but not this one so some would help, I would apprecitiate it!
Re: Map Sensor Help On a B18B Swap in to CRX Si (dynasty-x-motorsport)
The map sensor doesn't care which plug is used. I'd use the map sensor on the tb. You don't need a new plug, just extend the wiring and then remove the map sensor on the firewall.
Re: Map Sensor Help On a B18B Swap in to CRX Si (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 »</TD></TR><TR><TD CLASS="quote">The map sensor doesn't care which plug is used. I'd use the map sensor on the tb. You don't need a new plug, just extend the wiring and then remove the map sensor on the firewall.</TD></TR></TABLE>
Yes, just use the MAP sensor on the B18B throttlebody, no need to change the throttlebody either. You should be able to unclip the original MAP wiring from the firewall and it will have just enough slack to reach.
